Good afternoon all,
As a result of intense collaboration between WixWacing and myself, we have upgraded the forum software to PhpBB version 3. This has allowed us to bring back features such as the side bar.
Migration should be seamless for all, however if you have any problems logging in as passwords may not have migrated across (due to a potential incompatability between phpbb 2 and phpbb 3, all you will need to do is follow the 'forgotten password' process on the login screen).
Just be aware that images and links created using normal HTML codes will be updated to reflect the correct BBCode required in time, so some reviews etc are currently broken and not showing images. Will be rectified as soon as possible!
When you try making a post, due to phpbb 3 for security reasons disabling HTML coding, please check the FAQ for inserting images and links if you are not sure how. Pretty straight forward, not much changes just the tags preceeding the code.
Other than that.... Enjoy!!
-- Rob and Phil
