How to replace Revell Pick up Shoes
Postby chuckjoyce » Sun 26 Dec, 2010 1:31 pm
I have only recently started to collect the Revell Monogram Nascars.. I would like to know how to change the pick up shoes (braids).
chuckjoyce
Re: How to replace Revell Pick up Shoes
Postby wixwacing » Sun 26 Dec, 2010 3:20 pm
Hi Chuck
I have always modified the existing guide successfully, check out towards the bottom of this link:
Revell / Monogram McLaren M6a
The alternative is to buy the Ninco 'pro' guide and start from there. Can you post an image of the guide and chassis hole.
Postby chuckjoyce » Mon 27 Dec, 2010 5:44 am
Thank you for your answer.. but, I need to know how to replace the braids.. do you just pull the braid out of the guide and then shove a new one in - I don't want to break/bent/tear off something.. I am more than a "novice" at this - your assistance is more than appreciated
chuckjoyce
Postby wixwacing » Mon 27 Dec, 2010 4:05 pm
Hi Chuck
This might not be as easy. If you have a pair of replacement braids, it is a simple case of pulling the old braids out and inserting the new ones. If you don't have a pair of Revell/Monogram replacement braids, then things get harder. Having the ability and the tools, I personally would carefully unfold the brass aglet on the end of the braid with the tip of a small bladed modellers knife, pull the old braid out and insert a new piece and refold the brass aglet, and finally crimp closed again with a pair of small pliers. These should then simply push back into position.
Postby chuckjoyce » Mon 27 Dec, 2010 4:45 pm
Thanks!! That was what I was looking for.. I have two packs of new braids - just was not sure what to do - sometimes I "confuse" myself.. For your info, I removed the interior (driver's area) from one of the cars (4827) - 60% or more of the noise went away - the chassis set against the body at a number of places - I sanded the chassis at all of these points so that it does not touch - I still have some noise but not much.. learning as I go..
Thanks again!!
chuckjoyce
Return to News and Discussion
