Scalextric timekeepers hut
Tell us what you want!
Postby peter mansfield » Fri 08 Feb, 2013 7:46 am
Can anyone help me with the battery voltage required to sound the horn in these little buildings I can' seem to find this any where Peter Mansfield
peter mansfield
Re: Scalextric timekeepers hut
Postby wixwacing » Sat 09 Feb, 2013 12:03 pm
Hi Peter, give me day or two I have a good friend who collects this kind of stuff
Postby wixwacing » Sat 09 Feb, 2013 12:28 pm
Hi Peter, the battery you are looking for is a 1.5 volt (nominal) Type 'D' Battery. The nickel variations would be unsuitable
Check the link
D type battery
Postby peter mansfield » Sun 10 Feb, 2013 10:45 am
HI much appreciated thank you foryour interest pete
peter mansfield
Postby peter mansfield » Mon 11 Feb, 2013 7:26 am
Hi Wix well I had the right battery so it came down to adjusting the tuning screw on the back of the horn I can tell you there is more tuning space on an old transistor radio. When made there was adab of paint on the srew to show tuning position this given its age had chipped off and all I was getting was aclick the reason I Ichecked battery strength there is a miniscule turn between in tune and click sound but I did have to remove the locking srew to adjust to fine tune hope this all makes sense. once again thank you for your interest pete
peter mansfield
Postby wixwacing » Tue 12 Feb, 2013 11:38 pm
Hi Pete,
It sounds like they tune the same way as the old 60's car horns!
Return to Wanted
