The last thing I was expecting.....from Carrera!!
Tell us what you want!
Postby wixwacing » Sun 17 Jul, 2011 6:29 pm
G'day chaps
Just when I was least expecting it my Carrera McLaren M20 has s**t its pinion!! Most annoying. It is a white 8z pinion for the FF type motor shaft (1.5mm I think) Does anyone know where they are readily available or where I might get a generic one?? A nuisance really. The pinion has started slipping on the shaft. There is no splining on this motor so I suspect it has been asking a lot of it. The shaft has been lightly scored and Superglue has been applied and it is holding for now, but I suspect it is only temporary!
Re: The last thing I was expecting.....from Carrera!!
Postby kenneth » Mon 18 Jul, 2011 7:02 pm
Hi Phil
The scaley MOto GP Pinions fit, they will need to be secured with CA glue or loctite or something of that ilk.
Slot.it make a brass 1.5mm pinion for $6 each - a bit pricey.
Scale auto make a pack of 4 x 1.5mm 10teeth nylon pinions for $9.
the last 2 are available from Armchair.
have not seen the Moto GP ones for a while - i stole mine off my Moto GP bike.
Postby wixwacing » Wed 20 Jul, 2011 12:28 am
Hi Jordan
Do you know if these are 8 tooth pinions as per the original??
Postby kenneth » Wed 20 Jul, 2011 10:44 pm
Hi Phil
they are 9 tooth.
I know there was a box of scaley sport blue moto gp pinions that have about 6 or in the box all different sizes.
try here for them
http://www.slotcity.co.uk/product_info. ... -x5-p-2977
Return to Wanted
