Re glue that motor
Re glue that motor
Postby wixwacing » Fri 18 Jul, 2008 11:47 pm
For some time now I have been gluing in loose and errant motors to stop the incidence of hopping and juddering when racing in non magnet or board track situations. Ninco cars seem to be the worst offenders and one of the on going problems is that in an enduro or a race of several minutes, the 'hot' glue gets hot (heated by a hot motor!) and goes soft, whereby it then proceeds to demonstrate some of its hitherto bad habits.
What to do, well, if your not in a rush and don't need an instant fix, try painting a modicum of white 'PVA' glue carefully on the cleaned ends of the motor, refit the motor in cleaned mounts and leave it to dry for 24 hours in situe.
The motor is quite firm and doesn't move when it gets hot. I'm running a couple of models at the moment which have recently had this treatment and as yet they haven't let me down.
Re: Re glue that motor
Postby abarthmike » Wed 09 Jun, 2010 3:52 pm
Re un gluing and re gluing motor I do this with self adhesive aluminium foil tape. Only works of course on cars with flush motor so not Scaelextric. Easy to do, easy to remove and sticks like.. well glue.
Not my original idea.
abarthmike
Postby wixwacing » Fri 11 Jun, 2010 4:25 pm
Hi Mike,
I have seen this in other places. Is it effective for board racing, where there must be absolutely no movement in the motor or the rear end will tramp?
