Carrera 30K Motor
Carrera 30K Motor
Postby Waynew » Tue 13 Jul, 2010 10:12 pm
I purchased a Carrera 30000RPM tuning motor today and put it in one of my stock Carrera Nissan GT-R cars, the car had a E200 in it and I assume it is an 18000RPM at 12V. With the 30K motor the car is not even a fraction faster, but when you free rev it, it sounds like it is revving higher. Any idea's?
Waynew
Re: Carrera 30K Motor
Postby wixwacing » Wed 14 Jul, 2010 12:35 pm
I'd check the pinions first, do they have the same number of teeth? One tooth difference can generate more than 10% loss in speed.
Postby Waynew » Wed 14 Jul, 2010 4:41 pm
Yes Phil, Same pinions, I took the car down to Red Racer today and tried it on his track, and it is killer fast, I may not have enough power on my home track? I am running 14.8V Carrera power pack.
Waynew
Postby Cyph » Thu 15 Jul, 2010 8:37 am
Waynew wrote:Yes Phil, Same pinions, I took the car down to Red Racer today and tried it on his track, and it is killer fast, I may not have enough power on my home track? I am running 14.8V Carrera power pack.
Volts are fine, but whats the amp rating on that carrera power pack? That'd probably be the major difference between your power supply and red racer.
Postby RLackhan » Thu 22 Mar, 2012 12:59 am
Hi Guys. I need some advice. I race Carrera 132 digital cars with the wireless Carrera system. Can I use a 2,200uf 25v Capacitor to boost power on my Carrera E200 motor? Would it cause any damage to the motor or the digital chip? I plan to install it in my Nissan GTR.
Would appreciate your comments.
Thanks
RLackhan
Postby RLackhan » Thu 22 Mar, 2012 1:09 am
I forgot to mention that the Power Pack is the standard 14.8V and rated at 2.9A.
RLackhan
Postby dangermouse » Thu 22 Mar, 2012 11:21 pm
Motor Specs from
http://slotcarnews.blogspot.com.au/2007 ... -list.html
Carrera E-200, E-500 (FC-130) [21,081 RPM/12v] 26,000/14.8v, tested 18,058-20,6340 RPM/12v
at 14.8v the E200 is rated at 26000 rpm hence why the 30k motor wouldn't seem that much quicker.
cheers
DM
dangermouse
