fitting on board switch to convert anal to digtal
Postby pitman704 » Mon 02 Apr, 2012 3:08 pm
Hi to all
Have just joined your forum most impressed.
Have not done any slotting for about 50 years but my grandson and grandaughter have me going again.
Have decided to use a Ninco digital master track for starters and would like some info on installing a small switch incar to switch from analogue to digital.My son has a analogue track so would like to use some of the cars on both tracks (bothtracks are Ninco)
Cheers
pitman704
Re: fitting on board switch to convert anal to digtal
Postby dangermouse » Mon 02 Apr, 2012 4:29 pm
dangermouse
Postby wixwacing » Sun 08 Apr, 2012 12:09 am
Well you'll need a chip first which I assume you have, then you'll need a miniature DPDT switch and install it as per the link.....
Switching from digital to analogue and back
Once fitted, you can switch comfortably between digital and analogue!!!
Postby pitman704 » Tue 10 Apr, 2012 9:34 pm
thanks for the info
pitman704
