Removing wheels
Removing wheels
Postby chuckjoyce » Tue 18 Jan, 2011 11:03 am
Revell Monogram Nascar.. what is the best way to remove a rear wheel from the axle and how to put it back on?
chuckjoyce
Re: Removing wheels
Postby kenneth » Wed 19 Jan, 2011 1:42 pm
remove by twisting, put back on - glue.
Re: Removing wheels
Postby wixwacing » Wed 19 Jan, 2011 6:20 pm
Hi Chuck,
Just to elaborate, I suspect these are on knurled axles. What I would do is bring a small pot of water to the boil and hold the wheel to be removed in the boiling/simmering water for about thirty seconds. With a cloth in each hand, apply a light back and forward rotational action while pulling at the wheel at the same time. The wheel should work loose after several twists.
As for putting it back, apply superglue (cyno-acrylate) to the sides of the axle shaft and refit the wheel with the same twisting motion. If you haven't used super glue before I suggest you have three or four dummy runs before applying the glue. Note also I said the sides of the axle. If you apply glue to the hub or the end of the axle, there is a chance the glue will form a hydraulic lock which will prevent you getting the wheel fully on. It will then dry out causing all sorts of problems.
Another solution is to mix and apply some epoxy resin. It takes longer to cure but this gives you a much longer handling time, but I personally dont think it has a strong enough bond without taking other measures.
Good luck
Re: Removing wheels
Postby littleshark » Wed 30 Mar, 2016 10:41 pm
This is my first post here, so hope not stating the obvious. When gluing wheels back on , I found that a cushion of air often prevented the wheel from going on to the axle. To overcome this. I picked out the smallest drill I could find and drilled a hole through the middle of the wheel, which is easier from the inside. Now when you push the axle on to the wheel air and maybe a tiny bit of glue is pushed through the hole. After doing this, you will be very unlucky if you can see the hole.
littleshark
Re: Removing wheels
Postby wixwacing » Mon 04 Apr, 2016 12:13 am
Another plausible fix littleshark, I recommend if you are doing it this way to use a 1/16th drill bit in a pin vice if you have one. I also suggest that if you are not in a hurry, remove the offending axle to do the repair, why's this? Trust me, if you get glue into the axle bearing you are going to have to strip it out and dismantle it to remove the glue!!
If you are at a race meeting there often isn't time to remove an axle, strip and reglue and reinstall, If you are gluing a wheel on the run, the best bet is to oil or grease the axle bush well before sliding the wheel back on the shaft, it should prevent excess glue taking hold.
If you are having issues with a model in particular I recommend to replace the original axle with similar alloy wheels and insert, this fix is pretty final.
